Group: DynoMotion Message: 9172 From: Hugh Sontag Date: 2/10/2014
Subject: Fwd: [DynoMotion] Trajectory planner questions
We encountered a similar problem. In our scenario, the Z axis was being driven at speeds that exceeded the values set in the Trajectory Planner, which caused faults in the SnapAmp.
Tom K provided a version that wasn't supposed to do this, version 431n or 431o. I can't find the email in which he mentioned which version it was, and we didn't get it, and now it's no longer available.
We are currently using version 431s. I believe it still has problems with our trochoidal milling operations. We tried cutting an aluminum bar, and took video of the operation. After 15 minutes, it appears that the machine was commanded to move into the uncut material at a bit depth of approx. 6 mm. The operation that should have been done was a circular motion with a stepover of .11 mm. Instead, it suddenly moved 1 - 1.5 mm in the -X direction, from what we can see in the video. For a 2 mm bit, that was the end.
Tom, does version 431s have the changes that you made to address the sudden Z-axis movements? I assumed it does.
Here's a frame-by-frame video of the bit breaking:
Hugh Sontag
---------- Forwarded message ----------
Date: Mon, Feb 10, 2014 at 8:41 AM
Subject: [DynoMotion] Trajectory planner questions
I am having problems with slamming deceleration/acceleration between g1's g2's and g3's.  I am using KmotionCNC version 4.31e.  This version does not have the "Arcs to Segments" check box
I have set the Acceleration values in the tool setup screen AND the init.c file to extremely low values to try to eliminate the slamming between segments,  but it will not go away unless I set the Collinear tolerance to a large value, like .2, then it runs smooth on most of the segments, but still slams on some of the segments and breaks the arcs into coarse line segments ( A .8" circle will have about 12 flat sides instead of being a smoth arc ).
It feels like the Acceleration/Deceleration curves are being skipped and the machine is slamming to start and stop instantly between moves.  I have attached a random clip from a file that seems worse than some others
Kflop/Kanalog  AMC 30 amp DC servo drives, 127,000 steps per inch X,Y&Z.
Thanks, Todd
N195
N200   G00   X-2.6291 Y-1.8023
N205   G00  Z0.1
N210   G01   Z-0.51  F35.0
N215   G01   X-2.6008 Y-1.5288  F70.0
N220   G02   X-2.75 Y-0.9709 I1.6662 J0.7446
N225   G01   X-2.9111 Y-0.7481
N230   G01   X-2.4678 Y-1.8246
N235   G01   X-2.4523 Y-1.55
N240   G02   X-2.6346 Y-0.7842 I1.5177 J0.7658
N245   G02   X-2.4974 Y-0.1151 I1.7 J0.
N250   G02   X-2.5 Y0. I2.4974 J0.1151
N255   G02   X-1.9615 Y1.55 I2.5 J0.
N260   G01   X-1.9217 Y1.8221
N265   G01   X-1.7482 Y1.8202
N270   G01   X-1.7995 Y1.55
N275   G03   X-2.375 Y0. I1.7995 J-1.55
N280   G03   X-2.371 Y-0.1381 I2.375 J0.
N285   G03   X-2.5096 Y-0.7842 I1.4364 J-0.6461
N290   G03   X-2.3109 Y-1.55 I1.575 J0.
Group: DynoMotion Message: 9175 From: Tom Kerekes Date: 2/10/2014
Subject: Re: Fwd: [DynoMotion] Trajectory planner questions
Hi Hugh,
Yes we found that on Helical type motion we were assuming that XY would be the limiting condition.  Your case the motion was a bit unusual as the motion was more in in Z and combined with the Z axis being very slow relative to XY caused the problem.  Those fixes are in V4.31s.
Is your sudden shift repeatable?  Can you narrow it down to a code fragment that shows the problem.  Can you list your TP settings?
